Converter stall or transmission slip?
I've got my car locked into 3rd from 43-118MPH for the sake of tuning my A/F and timing.
The car has a 2800 stall Vigilante and makes about 550 ft/lbs of torque out of the 396 with 9psi of boost.
If I'm cruising at 50mph/2800rpm and nail it, the RPMs flash to about 5100 and slowly climb to 5700 over the next 4 or so seconds while the car accelerates from 50 to 90 or so.
I'm accustomed to high stall off the line, but this seems a little weird. Is it normal for a higher stall car to rev up to 5K+ like that and just accelerate while the RPMs stall somewhat constant, even at speed?
Thanks,
Dave
Thanks,
Dave
It's definitely not normal unless the converter were very loose (which a 2,800 stall should not be). But as to why, I really can't say. Is this a new behavior, or did it start after making some kind of change, or what?
Rich Krause
Rich Krause
Re: Converter stall or transmission slip?
Thanks,
Dave
Thanks,
Dave
2800 based on a stock LT1, I guess.
THe 396LT4 with 9psi stalls it to about 5000.
The 396LT4 with no boost stalls it to about 3800.
So I think its a torque issue :-)
Rich Krause
So who makes a stronger converter than Vigilante?
They seem to be about the same as ProTorque, and I've been launching my ProTorque behind a ZZ502 with drag slicks for years without ballooning. What makes you think the Vigilante can't take it?
In any case, it sounds to me like your problem is your converter. I have seen the behavior you describe when a converter was simply too loose.
Rich Krause
Vigi should have no problem building you a converter tailored to your specs and should take the power level with no problems. As Rich said, you are probably simply just overpowering that converter or it is stalling so high the computer is doing backflips.
