conversion
Old Apr 2, 2006 | 10:34 PM
Daniel6718's Avatar
conversion
if you do a conversion from 6-sped to automatic what all do i have to change, besides remove the 6 speed petal ect...and what do you do ith the switch to release the key in the ignition? will it even be affected by this?
Old Apr 3, 2006 | 12:16 AM
kingslam's Avatar
Re: conversion
you need an A4 Wire harness and either re-flash the PCM or get an A4 one to run the trans, and yes you need to re-route the cluthc pedal safety switch to the auto shifter PNP (park neutral position) switch. Try and find a tuner on here from TX to help you out..
Old Apr 3, 2006 | 05:52 AM
Sporty-X's Avatar
Re: conversion
hum ... if you were closer than me, i would have love give you my A4 for your 6 manual.
I'm dreaming of a 6 manual
Old Apr 3, 2006 | 10:26 AM
Daniel6718's Avatar
Re: conversion
ok nevermind...found some1 that will rebuild a t56 cheap...think ima go that route, just ned one now!
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
