Clutch release point at top of travel like it's adjusted too tight
Old Oct 8, 2007 | 08:34 PM
JP95ZM6's Avatar
My clutch now feels exactly like a cable-style clutch with no freeplay, as if the clutch cannot fully engage because the cable is too tight, and the fork is keeping the clutch from fully engaging. But of course it is self-adjusting hydraulic.
Last Wed at the track I thought either my clutch was slipping a bit in 1st, or there was smooth tirespin. I had not driven it since then. Today I drove it and noticed my clutch engagement point is within 1/8 inch or less of the pedal's 'untouched' position. I can pull the pedal up another inch or so, but from where it rests, I barely move it and the clutch releases. It used to be lower, and more progressive-feeling. Also, the clutch is engaging softer, enough that does not chirp 2nd like it used to. Again, like it is not applying full pressure.
It's a Centerforce DF with about 4000 street miles and 21 dragstrip runs, on street tires. Broke in for a few hundred miles of city driving before racing or dyno. So I hope it's not shot YET....I did smell it a little bit on my very first few launches when I was getting the feel for it.
What would cause a hydraulic clutch to feel & act like a too-tight-adjusted cable clutch?
Additional info: After my last drag run, I missed 4th and there was a major shudder in the car. I didn't mis-shift, but maybe clutched too fast. No grinding, but no engagement either. ON hard accelerations, the car would clunk like something hitting the underbody after that, maybe a loose LCA or something. Perhaps this is unrelated, but info never hurts.....
Old Oct 9, 2007 | 11:23 PM
Daniel6718's Avatar
rep-lace the clutch fluid...its normal for it to ruin after it gets hot...typical problem in ls1 cars...
not sure what your problem is though...worn clutch wont engauge until the top...when its new its at the bottom...my clutch does that now its about 1 inch from the top and its annying
Old Oct 10, 2007 | 06:40 PM
JP95ZM6's Avatar
Thanks Daniel. After discussing with a few people I really doubt I could have worn it out so fast on street tires, but if I can't figure anything else out I'll pull the trans and look at it this winter.
I played with it more last night, and the pedal effort feels way too easy at the release point, too. The further I push it, the firmer it gets.
BPS
9
Mar 5, 2015 10:51 PM
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
HectorM52
Jan 30, 2015 11:08 PM
edman
Jan 25, 2015 02:41 PM
siguy
Nov 27, 2014 10:07 AM
