Clutch Question?
Old Oct 29, 2007 | 07:24 AM
DAVE00's Avatar
Question Clutch Question?
Ok got another question for ya? I pulled the tranny this weekend to change out my Centerforce Dual friction clutch assembly and noticed I have some issues. First, I am taking the flywheel to be resurfaced as it definitly needs it and second, the clutch was missing 4 friction pads on the pressure plate side? It looks like they completely delaminated and just came off, while the remaining 5 are clean looking with very little wear. Has anyone ever seen this happen before? Also, there was some oil/grease in the bellhousing but I think this was from a leaky pan that was fixed a few weeks ago, as the rear main is bone dry. I am not sure if I am going to tackle the rear main as the motor has less than 20K on this seal and in his infinate wisdom the guy that built my motor switched back to the older style 2 piece rear main seal from GM from the standard one piece in the motor. Could the oil on the clutch cause the delamination issues and what are the signs of a leaky main vs. oil from a leaky pan seal? Also, I can send pics of the Clutch and Flywheel if you need them to see what is going on. Any help please???
You can find pics here:
http://s239.photobucket.com/albums/ff292/wdaveweaver/
Old Oct 29, 2007 | 09:21 PM
Green96Z's Avatar
Did you feel a lot of slipping in the clutch before you fixed it? Sounds like the oil pan was at fault, but you already fixed that. If you have any doubts about the rear main, you can replace it, look here for help:
http://www.pharmacy.arizona.edu/staf...RMainSeal.html
Oil on the clutch disk might have caused a lot of heat buildup and could have torn it apart, but I'm just guessing. After you do the clutch, put some miles on it and then unbolt the inspection cover and see if there is any oil in the bellhousing again. If not, then you're in the clear.
And your crank might have been designed for a 2 piece main, there is a difference in the cranks (though I have no idea what). Good luck man
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BPS
9
Mar 5, 2015 10:51 PM
Newgmman
Feb 25, 2015 02:53 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
