Clutch question
Old Jun 18, 2005 | 10:22 AM
97Transam123's Avatar
Clutch question
I need to know what clutch to buy i have the car in sig and its got 4.11's and i need to know what clutch to buy i was thinkin stage 1 but then my dad wanted me to go up higher and go to a stage 2 or 3 and i think stage 3 is overkill but i want to know your thoughts. i plan on headers and alot of boltons in the near fiture no motor work yet though I need quik replys because im gona buy from thunferacing and they have a fathers day sale
Old Jun 18, 2005 | 11:12 AM
96PTKZ28's Avatar
Re: Clutch question
For your mods a SPEC stage 2 would suit your needs just fine. I have heard good things about the stage 3 with ceramic pads, but that clutch is for more serious mods. I have had good experience with Mcleod (street twin) although it is VERY expensive and way overkill unless you plan for a future power adder or some extensive engine mods. You can't go wrong with SPEC. Just give them a call, tell them your plans and they will recommend the proper stage along with clutch material for your setup. FYI if you are plannng more mods, opt for the stage 3, then you can grow!
Old Jun 18, 2005 | 04:26 PM
Josh'95Z28conv's Avatar
Re: Clutch question
Yes, yes you can. Spec can get their stupid discs from throwing springs out. They offered me a new clutch for 1/2 price, but I might pass, even though my car will sit in the garage on jack stands untill I can afford the street twin. My friends just went out on thursday as well. Spec sucks. Dont buy spec.
http://community.webshots.com/album/356140671QRXNyK
Mine had under 15k miles, and my friends is only a year old.
Old Jun 20, 2005 | 10:18 AM
tywe's Avatar
Re: Clutch question
Totally agree.. Same exact issue with my second Spec clutch and Spec didn't offer to give me anything at half price.. First clutch they gave me was manufactured backwards, should have known at that point that their quality control was worthless..
Old Jun 22, 2005 | 10:09 PM
blackztpi's Avatar
Re: Clutch question
I'm really looking for a good clutch as well. help!
Old Jun 22, 2005 | 10:33 PM
fireman's Avatar
Re: Clutch question
Just installed a new RAM clutch in mine the other day. I forget which exact one it is, but it is smooth as silk on takeoff and the shifts. Its the one with full metallic on one side and organic on the other.
Old Jun 23, 2005 | 08:44 AM
Black_95Formula's Avatar
Re: Clutch question
I just went through the hassle of buying a Spec II (when my engine was stock) and having it fall apart on me. Finally I just went with the best (McLeod ST) and after a little hickup (they made the flywheel bolts too long) the clutch is so sweet! Drives JUST like stock yet grips like a ****! I highly recommend.
Old Jun 23, 2005 | 08:45 AM
Re: Clutch question
McLeod also sells a single disk which may be more appropriate for your setup. Just my $.02
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BPS
9
Mar 5, 2015 10:51 PM
Newgmman
Feb 25, 2015 02:53 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
