Clutch noise, now starting problems.
Old May 20, 2010 | 11:04 AM
rpinson's Avatar
A couple of days ago I left work and when I started the car, the clutch made a terrible grinding noise when it was pushed to the floor.
Very similar to this: https://www.camaroz28.com/forums/sho...t=clutch+noise
Right after that started, I began having starting issues as well. The car is very slow to crank and will only do so at all if I haven't driven it in a few hours. If it starts and I turn it off and try to start it again, it won't. Also, I noticed last night that if I push in the clutch while I'm driving, the noise only last a couple of seconds and as soon as it stops, my voltage drops and the lights in the dash and headlights dim. As soon as I release the clutch, everything goes back to normal.
Are these two things even related? I don't even know where to start.
Old May 20, 2010 | 11:21 AM
rpinson's Avatar
It's a 95 z28 if that matters/helps. Replacing the battery did nothing.
eazyZ
Mar 1, 2015 07:12 AM
Fatdog2
Feb 12, 2015 12:24 PM
karnykamaro
Feb 2, 2015 01:37 PM
HectorM52
Jan 30, 2015 11:08 PM
jj71787
Dec 30, 2014 02:15 PM
