clutch master cylinder problem
my master cylinder jammed while i was driving the push rod bent and everything couldnt get the tranny out of gear. so i replaced the master
cylinder only. got it on the car started pumping the clutch it was very loose
all of a sudden after pumpin the pedal 5 times freely it wouldnt go down anymore it was jammed again. I took the whole kit off the car slave and all
to bleed assuming there was air in the line. I noticed when i take the line off
the master cylinder its ok the rod pumps in and out freely put the line on and i cant even force it down with all my strength. funny thing with my old master cylinder the one that bent i just realized without the line on it it pumps
freely too. before i took the damaged one off the car it had the same symptoms couldnt push the pedal down any suggestions before i buy a whole
new kit for $175.00.
stockssn2o
May 25, 2015 08:54 AM
Ringmaster72
Mar 19, 2015 03:32 PM
