Clutch Isn't Fully Disengaging (Spec 3+)
2000 WS6
Spec Stage 3+ Clutch
Symptoms:
-Clutch engagement is literally right off of the floor
-Cant shift out of first or into second near redline until revs drop
-Popping out of 3rd occasionally
-Light Grinding into 4th & 5th
Previous owner had "new hydrolics" installed right before i bought it.
So what exactly did they do wrong?
-Not leaking any fluid
-Could it be a simple bleeding issue?
-Slave cylinder not shimmed properly or shimmed at all?
I need to sell the car, but want to get this issue fixed first. I am prepared to
drop the tranny to look at the slave cylinder or clutch setup if necessary, but would rather not if its avoidable. Any help would be appreciated. Thanks guys.
Symptoms:
