clutch install tips
Old Aug 9, 2005 | 07:25 PM
redlined4816's Avatar
clutch install tips
going to install my spec 3 into my 98' z28 tomarrow morning, any last minute tips?
Old Aug 10, 2005 | 06:42 AM
TQdrivenws6's Avatar
Re: clutch install tips
When separating the trans from the bellhousing, look for a pry point mid way up on either side of the trans. Mine was siezed up too tight to come loose by shaking it like many online guides suggest, so we had to resort to prying. 5 minutes later the transmission was on the ground. Also, do not remove the clutch fork, just pull it out radially from the clutch, some online guides say to take out the bolt, but that is completely unneccessary.
Old Aug 10, 2005 | 02:58 PM
cwaldt's Avatar
Be sure to have the clutch fork in hand pulled back from the shaft. When I took mine out I wasn't paying attention and got the whole thing hung up. Needless to say it took a lot of wasted time to get it out. If you do get stuck and your fork is pulled forward you'll have to undo the bolt on the fork little by little.
Old Aug 10, 2005 | 07:49 PM
twiztedone01's Avatar
for the drill mod, which end of the line has the restrictor? the slave cylinder end or master cylinder end?
btw: this is redlined4816 on my friends computer
BPS
9
Mar 5, 2015 10:51 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 09:07 AM
HectorM52
Jan 30, 2015 11:08 PM
