Clutch install help
Old Mar 13, 2004 | 07:34 PM
BigKid's Avatar
Question Clutch install help
Installing a new clutch on a 94. When I tighten the pressure plate bolts to 22ftlbs, the pressure plate housing does not seat onto the flywheel. There is a small gap between the two. Is this correct?
Old Mar 13, 2004 | 07:49 PM
Robs97Z28's Avatar
are you sure you have the disk in the right way?
Old Mar 14, 2004 | 12:03 AM
zx1216's Avatar
The pressure plate should sit on the flywheel, what clutch are you installing?
Old Mar 14, 2004 | 12:13 AM
BigKid's Avatar
Valeo clutch from Autozone.
Nov 18, 2023 07:21 PM
BPS
9
Mar 5, 2015 10:51 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
