Clutch install
Old Sep 9, 2015 | 04:47 PM
Bxlt1's Avatar
Clutch install
Whats up everyone bout to help my cousin out with this. We have everything from flywheel to all bearings and a few cases of beer lol Where would he find out all the steps and more importantly specs on torque ex.flywheel pp etc. also should the pp bolts or all bolts be loctite? I suggested yes,red tho on fw and pp only.thanks
Old Sep 10, 2015 | 12:27 PM
Re: Clutch install
The stock install, including torque specs, is detailed in the 1996 factory manual, volume 1 of 2, part 2, section 7C. You can download a copy of the manual here:
LINK: 4TH GEN SERVICE MANUALS; 82-02 PARTS DIAG; 99-02 WIRING DIAG - Fourth Generation Pontiac Firebird (1993 - 2002) - Firebird Nation
Copy of chart from page 7C-14 below.
If you are installing an upgraded aftermarket kit, did it not come with instructions? May have different recommendations than the stocker.
Old Sep 11, 2015 | 07:46 AM
Bxlt1's Avatar
Re: Clutch install
Thanks injuneer.btw its a stage 2 clutch,that i believe is also replacing a stage 2.the sheet that came with the kit is more of a warranty and break in period not really specific to a t56.but im sure stock specs should be good?
Old Sep 11, 2015 | 08:23 AM
Re: Clutch install
Should be OK, since they didn't indicate any different.
Old Sep 13, 2015 | 07:53 AM
Bxlt1's Avatar
Re: Clutch install
Thanks injuneer.we should start today ,setting up mainly we mite have the trans seperated from bell by noon.lol wishful thinking.were gonna takke our time this isn't a daily. I know im gonna hit this site up soon with many questions.
Old Sep 15, 2015 | 09:03 AM
Bxlt1's Avatar
Re: Clutch install
Am. Quick question basically the torque specs on fw and pp and everything else is same as ls1. We have everything out taking our time with this.my main concern is torqing everything correctly.
Old Sep 15, 2015 | 12:14 PM
Chimera96's Avatar
Re: Clutch install
74 ft lbs for FW
22 ft lbs for PP
I don't know what "LS1" specs are...but these are TQ for LT1 clutch
DO NOT over TQ the PP bolts or you will have disengagement issues. PP bolts for LT1 are specific, not just any bolt. Use the factory ones or ARP now makes them
Old Sep 15, 2015 | 02:13 PM
Re: Clutch install
Originally Posted by Chimera96
74 ft lbs for FW
22 ft lbs for PP
Same LT1 spec as shown in the photo of the LT1 factory shop manual above.
Old Sep 17, 2015 | 08:31 AM
Bxlt1's Avatar
Re: Clutch install
Am. So far going good it's not our first tranny but definately a first t56. Like everyone else wish we had a lift but jacks,ramps and stands,some wood worked.now the fw is on loctite the bolts pp and clutch on,bout to bolt housing on now the fun begins.thanks again everyone will keep ya posted
Nov 18, 2023 07:21 PM
BPS
9
Mar 5, 2015 10:51 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
