Clutch fork problems
Old Dec 26, 2007 | 11:32 PM
blwnlt4's Avatar
Ok, so six speeds inc. just got my tranny back to me and i installed it earlier tonight.. and i have had this trans out so many times in the last 2 years and finially i think i got someone to rebuild it right, except for 1 problem, i have a brand new clutch fork, hardly even 500 miles on it if that. Everytime i push the fork up to lock it onto the release bearing it falls back down, it simply wont stay and lock into place, is there anyway the clips on the fork could have possibly been damaged? or something i am missing?
i tried to hold it up onto the bearing as best as i could and install the slave cyl. but as soon as you apply pressure it pops off the fork and the fork falls back down... i dont know what else to try and getty pretty tired of R&R of the trans on this car.
Any suggestions are great.
Old Dec 27, 2007 | 12:10 AM
Green96Z's Avatar
http://www.pharmacy.arizona.edu/staf...kinstalled.jpg
The spring should hold on to the t-stud, which is what the fork pivots on. Take the t-stud off the tranny and slide it into the fork and make sure it engages right. If not, you might be able to bend the spring clip so that it does.
Old Dec 28, 2007 | 12:44 AM
blwnlt4's Avatar
yeah i know how it works i just couldnt figure out why it would not stay on the bearing, i ended up just pulling it all back out and looked close and it seems that the clips were banging the side of the t-stud and not popping over it so i just bent them with some needle nose and all is good.
Six Speeds Inc did a real nice job on the tranny rebuild it drives and shifts like brand new, for once.
Thanks for your help.
Old Dec 28, 2007 | 01:15 AM
Green96Z's Avatar
No problem. Wasn't trying to insult your intelligence or anything, just being as helpful as possible . I got my tranny from Six Speeds Inc too. 1500 miles and working awesome! (knock on wood)
Old May 19, 2008 | 07:00 PM
davieboy_70's Avatar
SAme thing happend to me!!
I had the same exact problem I ended up buying a new fork ($80) because my clip was bent and it could not be bent back to hold the clutch fork in the right way.
Old Jan 13, 2009 | 12:25 AM
CreatiVe2's Avatar
Davie, did that solve the problem? was the new spring tight enough?
i have the same issue, and just ordered a new fork...
Old Jan 25, 2009 | 06:19 PM
c1989rs's Avatar
i had the same problem when i got mine i had to tighten it in to place with a piviting ratchet wrench it was a nightmare but it works great now
BigWil
Mar 29, 2015 12:24 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
