Clutch Fork Bolt?
Old May 1, 2007 | 01:10 AM
iansane's Avatar
Clutch Fork Bolt?
So I'm trying to tighten the t-bolt that holds the clutch fork down and I'm having quite a difficult time. Anyone know of any tips/tricks to get at it? As it sits I've got the slave cylinder off and I'm trying to reach up in there with a 13mm.
Old May 1, 2007 | 09:20 AM
OBE1 95Z28's Avatar
If it's loose, you'll want to remove it and add loctite. I had one vibrate loose while driving and it snapped off leaving me stranded. Not what you want to here, but I pulled the tranny to fix it.
Old May 1, 2007 | 10:46 AM
iansane's Avatar
I could never get it tight enough when the tranny was separated? The fork wouldn't reach to the TO bearing?
Old Sep 18, 2007 | 01:32 PM
Firebird_fr3ak's Avatar
bump for same problem, did you get it?
Old Sep 18, 2007 | 09:47 PM
iansane's Avatar
Haha. Yeah, I got it. Yank the fork towards the drivers side and it'll slide completely off the stud. Or at least enought to tighten the bolt! HTH
Old Jan 10, 2009 | 02:01 PM
CreatiVe2's Avatar
how tight does it need to be? sorry for diggin an old thread, but i think that is whats causing my disengagement issue :/
Old Jan 10, 2009 | 04:31 PM
iansane's Avatar
18 lb/ft.
And use loctite. I used red. And then went with a hydraulic TO.
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
