clutch dragging
Old Jul 8, 2010 | 12:59 PM
ralf's Avatar
clutch dragging
After replacement of stock disc with McLeod performance one I immediately ran into the problem: it is quite hard to shift gears and sometimes even impossible to get into reverse. When I shift into 1st gear with fully depressed clutch pedal the car tries to move ahead. Garage people tell me that it is not possible neither to change oil nor to bleed the clutch lines as system is fully closed with no bleeding vents. Also it seems that when the car is cold its almost okay and problem arises after some driving time. Any ideas please? Its T56 and oil level is okay.
Old Jul 8, 2010 | 02:16 PM
wrd1972's Avatar
The measurement of the disk between compressed and NON compressed exceeds the OEM spec and thats why it drags. This measurement (air gap window) is small on our pull clutches and this is a common problem.
Get an adjustable master cylinder that can provide more throw, meaning more fork travel or get a different disk.
Old Jul 8, 2010 | 02:44 PM
ralf's Avatar
By different disk you mean thinner one? The McLeod one I have now is about 50% thicker indeed than previous one.
Old Jul 8, 2010 | 08:57 PM
wrd1972's Avatar
Thickness is not really what I am saying. Its the difference between compressed and NON compressed.
Measure the disk unclamped, then clamp the disk in a vice and measure again. Subtract the smaller number from the bigger number. This measurement exceeds OEM spec and there is not enough clutch release movement and bada bing, you got drag.
You need a disk where that measurement is lesser or an adjustable like I said above.
Old Jul 8, 2010 | 11:15 PM
ralf's Avatar
Okay clear. But all adjustable master cylinders either RAM or McLeod which are offered in the market are for LS1 (1998 onwards) - will it fit LT1?
Old Jul 9, 2010 | 07:45 AM
wrd1972's Avatar
Yes, they are interchangeable.
Old Jul 15, 2010 | 02:38 AM
97SS0594's Avatar
you can change the fluid. im doing it right now... Im having the same issue, the car wasnt doing the drag, then it started doing it one day... i have the adjustable mcleod master, nomater where i adjust it to it drags.
Ericksd
Jan 20, 2016 06:07 PM
Jake Bialke
Sep 24, 2015 11:31 AM
Ericksd
Sep 16, 2015 07:08 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
