Can I change my 1st gear ratio in my 700r4?
Old Dec 18, 2003 | 01:11 AM
90rocz's Avatar
Is it possible to change my 1st gear ratio to like 2.75 similar to a 2004r??
Old Dec 18, 2003 | 04:01 PM
Pro Built Automatics's Avatar
There are no after market gear ratio changes for the 700R4/4L60E. If you use the right torque converter, you can hide the big rpm drop on the 1-2 shift.
Old Dec 18, 2003 | 10:40 PM
90rocz's Avatar
Thanks, I have a SLP 2400-2600 convertor..
Is the 2004r gear set interchangeable??
Old Dec 19, 2003 | 01:25 AM
There is nothing interchangable between the 2004R & the 700R4/4L60E.
Old Dec 19, 2003 | 12:47 PM
90rocz's Avatar
How is changing gear ratio's accomplished in automatic transmissions, swapping the entire Planetary set???
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
simple
Aug 2, 2002 03:30 PM
