Camaro performers 8 speed auto????
Old Oct 25, 2005 | 10:17 AM
  #16
mike 96 ws6's Avatar
Re: Camaro performers 8 speed auto????
Originally Posted by Joe 1320
Am I correct that the GV unit was added to a 4L60/4L60E ? If that's the case, count me in as another old fart that will be adding one.
Not on Fred's car.
Originally Posted by Injuneer
since my goal was simply to provide the non-O/D TH400 with an O/D gear.
Old Oct 25, 2005 | 10:47 AM
  #17
Joe 1320's Avatar
Originally Posted by mike 96 ws6
Not on Fred's car.
I already know that. I was referring to 2cub49's post.
Old Oct 25, 2005 | 11:26 AM
  #18
2cub49's Avatar
Yes I've got one on a 460LE.
Here's some pics. I started with a Jegs short torque arm but it was too noisy for me so I modded my stock mount and arm and bolted it to the Jegs floor plate. She ain't pretty but is as quiet as stock and stiffer.
http://photobucket.com/albums/v142/2cub49/
Old Oct 25, 2005 | 12:26 PM
  #19
Joe 1320's Avatar
Thanks, you made my day! This is just what I need to be able to drive mine on a daily basis.
Can you fill me in on what you did for the driveshaft?
Old Oct 25, 2005 | 03:41 PM
  #20
2cub49's Avatar
I shortened the stock one.
An aluminum one won't work because of the dampener on the snout end.
Old Oct 25, 2005 | 03:42 PM
  #21
2cub49's Avatar
The GV comes with it's own special snout
Old Oct 25, 2005 | 05:06 PM
  #22
Joe 1320's Avatar
Thanks for the insight. This is gonna be fun. I can't wait to have a decent cruising rpm again.
Old Oct 25, 2005 | 07:48 PM
  #23
2cub49's Avatar
If you do a GV with the 4l60e adapter, put the adapter upside down (it will fit) so the speed sensor unit doesn't hit the tunnel and cause fit problems.
With the adaptor upside down the speed sensor unit will be on the bottom.
You need more pinion height using a couple of spacers on the trans mount or you'll get console vibration.
Also if you have or are going to put in longtubes, you'll have to have a custom ypipe made to go around the GV unit.
Short torque arms you can use are Spohn,
BMR Trackpac,
Jegs,
or you could mod the stock arm and mount like I did.
You don't need the electronic controls as manual mode is the best. The 43 mph shift is a bit hard especially under throttle and it interferes with the gear you're in.
Old Oct 25, 2005 | 09:33 PM
  #24
Sorry about that.
Old Oct 26, 2005 | 01:56 AM
  #25
1badasZ's Avatar
as far as racing does the GV make the 4l60E stronger? ive never had any luck with them...or would i just be better off swapping to a t350 or t400?
Old Oct 26, 2005 | 02:12 PM
  #26
Joe 1320's Avatar
It doesn't change the strength of the transmission, it merely gives you an extra overdrive gear for cruising.
sdn1997rs
Dec 30, 2014 08:30 AM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 30, 2014 08:41 AM
Jul 4, 2005 05:00 PM
