C6 Wheels + Lowering = Bad Vibration?
Old May 11, 2009 | 07:38 PM
seanwales's Avatar
Hey guys,
I have a 1995 Z28 Vert. Recently I went to my tire shop & had them install the Eibach pro kit 3831.140 along with a set of C6 Replica's (not sure what brand)wrapped in Nexen N3000 Tires (245/40r18 front, 275/35r18 back) My setup before was the factory 16" 245/50r16 & it rode like a caddy smooth up to obscene speeds. Ever since the drop & new wheels I've have horrible vibrations & took the car back 3 times to have them try to figure it out. They've road force balanced it by the center hub & last time using their new finger setup (which uses the lug nuts) & it doesn't seem to get rid of the vibrations. I have the old Bilsteins up front (B46-1913 & newer BE5-2407's in back) Right now the vibrations aren't too bad at about 80 but at 70 & 90 plus it's a chuck wagon going down the interstate. Also going over bumps feels like the shocks can't keep up with the higher spring rate. I realize by going up to a 18" wheel that it will be harsher & I've read about the issues with both sets of shocks.
So far my thoughts are:
- Maybe the pinion angle is off from lowering?
- Need better shocks, but probably not the vibration issue
- I have him searching for the factory wheels so I can isolate the new wheels / tire combo & put the old ones back on.
- If anyone near Nashville, TN has a set of (known good wheels & tires) I could borrow I'd be glad to pay some $$ to try them out
Any other ideas would be appreciated
Thanks,
Sean
Old May 11, 2009 | 08:03 PM
wrd1972's Avatar
I would go after the pinion angle first
Old May 13, 2009 | 06:36 PM
seanwales's Avatar
Thanks for the reply. I'll look into that.
Anyone else with the same lowering kit end up having to move to an adjustable torque arm?
Old May 13, 2009 | 09:55 PM
95zsean's Avatar
Like wrd1972 said its the pinion angle off ,and thats putting strain on the u joints and thats where you getting the vibration.Search and you will find LOLTS of posts on what else needs to be done after you lower your car. For example; it needs a front end alinement, but you should use different numbers than stock.
Old May 14, 2009 | 08:29 AM
seanwales's Avatar
95zsean thanks for the reply, an alignment was performed when the lowering kit was installed, but I didn't get a copy of the numbers. Since you seem to have a similiar setup which adj-torque arm did you go with & what's the recommended alignment specs for our lowered z's. I'd like to get the one that moves the front mounting point away from the trans, but since it's lowered I wasn't sure as to which mfr had the best clearance.
Old May 14, 2009 | 07:34 PM
95zsean's Avatar
All my suspension stuff is UMI, and my Adj. torque arm goes to the trans, and is set -2degrees. Unless your going to make "Alot" of power I'd use the trans mount one as the ones that mount to the tunel tend to vibrate inside the car.
I used "Injuneer's" line up numbers: +4.0 Caster, -1.0 Camber, 0.1 Toe, and have had NO wear problems.
This year I did the LS front break upgrade and he could no get those numbers!!!! but it was close.
I also added KYB AGX's front and back and it made a "BIG" differance, no more bouncing..
I did alot more than that to it this winter....I guess i should update my sig......
karnykamaro
Feb 2, 2015 01:37 PM
HectorM52
Jan 31, 2015 07:29 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
mattszm6
Dec 14, 2014 07:09 AM
squarehead
Nov 21, 2014 08:02 PM
