built tranny, new program??
Alright, those of you using Franks or Danas or anyone else's tranny for that matter, what did you do for computer programming? I know Frank puts in a better pump, so there is nothing to do with line pressure, but what about shift points, part throttle and WOT? Did you just install their trannies and go? Or did you midify your stock computer programming at all? Just looking to see what everyone did here!
Mine is a 95 Bird, will have a 4L60E very soon.
Cody
Cody
Re: built tranny, new program??
If your computer program is what you want right now, then mine or Frank's unit should not change much of anything here. If you want to make computer changes then I would use Ed Wright at www.fastchip.com one of the best in the business at computer programming.
Well, My motor is almost done being tweeked. I have Jeff Creech as my tuner from Carolina Automasters. But, I wanted to know, everything else being the same, do you need to change any program parts for the tranny by just swaping from a stock 4L60E to a Frank built 4L60E?
Noct
Jul 14, 2015 01:18 AM
