Break in?
Old Aug 22, 2003 | 12:00 AM
Rodrigues's Avatar
Break in?
I just installed the street twin, works great and I love it. How do I do this break in? Can I go WOT and just not shift hard? I heard 500 miles is a good guide.... It doesnt seem like it would break it in though if you just went 500 highway miles.
Old Aug 22, 2003 | 01:00 AM
AL SS590 M6's Avatar
Moderator
NO NO NO on the WOT. You need to do a lot of shifting and smooth easy take offs to bed the disc to the pressure plate and the flywheel.
When we did the SPEC stage 3 in Rods TT Formula on the first drive he got into the boost just a little in 3rd and the clutch slipped. After that he drove like he was supposed to with a new clutch and after 500 miles it holds 5500 rpm clutch dumps on the boost.
Old Aug 22, 2003 | 01:42 PM
PatriotTA's Avatar
Man the hardest part about the clutch install is the break-in. I didn't mind laying on my back and holding the flywheel while I ran bolts through half as much as I mind not going WOT for 500 miles But its worth it. Like AL said, there's resins in the friction material that need an EASY break-in period to properly seat. Otherwise, you will glaze your disc and it will not hold like it should. McLeod reccommends "500 miles of easy stop-and-go city driving" for the break-in. That was on a sheet of paper inside the clutch disc box when I bought my Dual Performance set. I still have about 20 miles to go on the break-in, and you can see how the clutch improves over the break-in period. Launch real easy, no slipping the clutch. Shift slowly, and don't take it above 3k.
Old Aug 22, 2003 | 10:39 PM
Rodrigues's Avatar
How are you supposed to launch easy without slipping the clutch?
Old Aug 23, 2003 | 01:36 AM
PatriotTA's Avatar
Just quickly but smoothly let off around 1.5k. Don't "pop" the clutch, but don't slip it too much either. Of course, it will always slip a little during engagement/disengagement, but from what I've heard the Street Twin is more of an on/off clutch anyway.
Old Aug 23, 2003 | 09:36 AM
Rodrigues's Avatar
I hope I didnt ruin it... I was slipping the clutch a little just to smoothly get going.
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Aug 17, 2015 09:50 AM
Cam's maro
Aug 11, 2015 07:45 AM
