brake rotors grinding bad on 12 bolt!
Can't figure this one out. I bought a used 12 bolt from a friend that has less than 100 miles on it. Awesome deal and he had no problems with it. I installed it and my brake rotors are pushed against the inside of the caliper. They just grind on there. There is no spacer installed on the rear end either. I ground down the calipers a bit to stop them from rubbing but they still do a little. Anyone else have this problem and know how to fix it???
Ryan
Ryan
Re: brake rotors grinding bad on 12 bolt!
No, it was out of an lt1. I helped him remove it too. From what I understand now, I should have shims placed behind the rotors to push them away from the caliper a bit.
stockssn2o
May 25, 2015 08:54 AM
