Bleeding The Clutch
Bleeding The Clutch
Ive Searched But Couldnt Find Anything About Bleeding The Clutch.it Worked Fine When I Pulled The Motor And Trans Out But It Seems To Have A Lot Of Air In It But I Cant See A Leak. If Someone Could Help Me Out I Would Really Appreciate It.
I found the perfect trick. Got this from I think Install University. When you have the trans out, cut a 1" by 1" hole where the bleeder will go in the floor. Makes bleeding a one man 30 minute job.
Nope. LS1 tech
http://ls1tech.com/forums/showthread.php?t=510788
Nope. LS1 tech
