Bad vibration when accelerating
Old Aug 26, 2005 | 11:59 AM
Penz's Avatar
Whenever i accelerate between 2500rpms and 4500rpms the car vibrates really bad. Its the whole car and not just one section either. It is rpm based and has nothing to do with how fast I cam going. No matter what gear i am in, it vibrates between 2500 and 4500. The weird thing is no matter how hard I am accerlerating, it quits after 4500 rpms.
Any suggestions?
Josh
Old Aug 26, 2005 | 02:58 PM
HaLLaSS's Avatar
Re: Bad vibration when accelerating
try checking your transmission mount. kinda sounds like what mine was doing right before it completely went. now every time i do anything other than baby the gas pedal it feels like the tranny's coming through the floorboard. it's the 2nd time in about 8 months that i've had to replace the freaking thing.
Old Aug 26, 2005 | 03:07 PM
DiabloGT's Avatar
did u put on longtube headers? because i just did with slp loudmouth, and the body vibrates like crazy and i dont know why?
Old Aug 26, 2005 | 04:50 PM
arieso94Z28's Avatar
You might think about checking to see if your driveshaft is balance correctly, I know some guys that had that same problem.
Old Aug 26, 2005 | 09:41 PM
Penz's Avatar
I know its not the tranny mount and yes it does have long tube headers but those are not the culprit either. I am thinking it might be the pinion angle and alos mention by BMR fab. when i had to talke to them about my trak pak torque arm. A friend mentioned today that it could be the rear end. Now, the rear end is in bad shape and on its last leg. It has so much play in it and howls like crazy. Do you think with the rear end being so bad it would cause it to vibrate like that?
94Z28LS1toLT1
Jun 30, 2015 12:22 PM
Apr 16, 2015 09:57 AM
karnykamaro
Feb 2, 2015 01:37 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
mattszm6
Dec 14, 2014 07:09 AM
