Anyway to force the A4 into Limp-mode 3rd gear only?
Is there any easy way to force the trans into 3rd only without going underneatch the car? Some fuse to pull or maybe a single power wire to cut.
My car will not go froward at all when I push the gas but will go into reverse just fine. I am assuming the 1-2 clutch packs or maybe the drum band is broke. But I want to see if I could possibly force it into 3rd just to see if I can move it.
Re: Anyway to force the A4 into Limp-mode 3rd gear only?
Pull the fuse thats labeled trans. I think its in the panel when you open the driver door on the dash. If not, its in the relay box under the hood. Should get you 3rd i believe with no power to the trans.
No... it's an electronic transmission. When it doesn't recieve a signal from the computer, it just stays in third as a "limp" mode so you can "limp" it home.
And I'm pretty sure it's a 1st/reverse band. If that band goes out, you wont have reverse either. Not sure though... maybe i'm think of another tranny.
Man, I wish it was a simple as pulling a fuse... But there is no fuse or relay labed for the trans.
I may be wrong but I don't think 1st and Rev. share a band. I do have reverse.
Does anyone one know which wire(s) in the wiring harness to the trans I would need to cut to force 3rd only limp home mode? Call me crazy but I feel good about this idea. I'd like to be able to drive it home.
The fuse that powers the solenoids also powers other things that the engine needs to run. I don't know if it will work, but you could try disconnecting the electrical connector on the side of the transmission.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ChrisFrez
Jan 18, 2015 08:05 AM
