Anyone using a 4.56 gear with M6 and Spray?
Old Aug 6, 2009 | 01:48 PM
DRIVEFASTKEEPLEFT's Avatar
I'm going to put in a set of 4.56 gears in the car and see where it gets me. The car is a lt1 M6 with a 28" drag radial on welds. I'll be shifting the car right around 6900. The car makes about mid 5xx to the tires on spray. I was wondering if anyone uses this set up and what you come through the traps with in 4th gear. Thanks.
Old Aug 8, 2009 | 02:53 PM
johnnyb's Avatar
6900rpms in 4th gear will put you at 126mph; right about what you trap now. You may want a little more tire though cause it looks like youll be veryy close to running out of rpm
f-body.org/gears
Fatdog2
Feb 13, 2015 08:19 PM
David Dorris
Jan 17, 2015 08:10 PM
tds1213
Nov 27, 2014 12:55 PM
Redbird
Jul 23, 2002 07:16 AM
