Adjust tv cable question
Old Jul 29, 2006 | 08:48 AM
94_camm's Avatar
Ok iam in the middle of doing my 700r4 conversion.How do i "Properly" hook up the tv cable? thanks
Old Jul 29, 2006 | 10:40 AM
n2ceptor's Avatar
Re: Adjust tv cable question
What type of vehicle????? Carb/FI?????????? Here's instruction on setting the cable up....
Throttle Valve Cable
The Throttle Valve (“TV”) cable must be installed and adjusted correctly for proper transmission operation. The TV cable adjustment affects shift point, shift feel, detents, and downshifts.
Adjust the TV cable after the transmission has been installed in the vehicle. Adjustment of the TV cable must be made by rotating the throttle lever at the carburetor or throttle body. Do not use the accelerator pedal to rotate the throttle lever.
1. Stop engine.
2. Depress and hold down the metal re-adjustment tab at the engine end of the TV cable.
3. Move the slider until it stops against the fitting.
4. Release the re-adjustment tab.
5. Rotate the throttle lever to its full travel position.
6. The slider must move (ratchet) toward the lever when lever is rotated to its full travel position.
7. Check that the cable moves freely. The cable may appear to function properly when the engine is stopped and cold. Recheck after the engine is hot.
8. Road test the vehicle.
Old Jul 29, 2006 | 02:32 PM
12SCNDZ's Avatar
You do know you need a '93 throttle body, right? '94-up don't have a pivot for the cable. You'll also need a '93 tv cable braclet.
Frank
CPT
Old Jul 29, 2006 | 05:38 PM
94_camm's Avatar
I bought this conversion bracket that goes onto my throttle body for a spot for the tv cable.whats the braclet? (94 camaro fi)
Old Jul 29, 2006 | 10:28 PM
12SCNDZ's Avatar
You need a bracket to hold the cable, and a pivot for it on your throttle body.
Frank
CPT
Old Jul 30, 2006 | 10:01 AM
94_camm's Avatar
do you have a picture or place where i can get this?
Old Jul 30, 2006 | 11:29 AM
12SCNDZ's Avatar
The top cable is the tv cable. The bottom is the throttle cable. Both cables attatch at the cable bracket.
Frank
CPT
Old Mar 17, 2007 | 02:46 PM
94LT1Maro's Avatar
Does the same hold true for a 305 TBI, mine will shift through the gears but at WOT it will not downshift.
Old Mar 18, 2007 | 07:47 AM
Vince @ FLT's Avatar
Yes it will be about the same setup as what frank from cpt posted. With no kick down I would say that your cable is out of adjustment or your cable is bad.
Old Mar 18, 2007 | 12:52 PM
94LT1Maro's Avatar
I adjusted it with the same method as before and i'm still not getting a WOT downshift, how do I determine if it's a bad cable?
Old Mar 18, 2007 | 04:23 PM
12SCNDZ's Avatar
Has this transmission ever been built, or the valve body or seperator plate changed?
Frank
CPT
Old Mar 18, 2007 | 04:54 PM
94LT1Maro's Avatar
No it hasn't been rebuilt, it's the factory 700R4 with about 143,000miles on it. I did finish up an engine swap recently and that is the only time it's been seperated from the engine to my knowledge.
Old Mar 21, 2007 | 06:27 PM
94LT1Maro's Avatar
Ttt
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
edman
Jan 25, 2015 02:41 PM
