Accurate trans temp readings from inspection port?
Old Apr 26, 2005 | 03:41 PM
DarkHorse's Avatar
Is the inspection port on the drivers side of the 4L60E fairly accurate in determining trans temp? I bought an AutoMeter Ultra Lite series trans temp gauge and want to get it mounted tomorrow.
Pretty safe installing the sending unit here? Seems to be mixed opinion on this.
Old Apr 27, 2005 | 02:21 PM
Red on Red WS6's Avatar
Re: Accurate trans temp readings from inspection port?
That is where I have mine hooked up and it works just fine. Mine runs around 130 to 165 deg. with a supercooler and 3000 stall.
Old Apr 27, 2005 | 02:27 PM
Makaveli's Avatar
anyone have a baseline stock temperature, or an OK operating temperature to compare it to? ive been planning on putting a gauge in the same spot too, im curious if there are any bad thoughts on it too.
Old Apr 27, 2005 | 02:35 PM
My car before the cooler was running around 190 to 220 with stock converter. That is pretty high even going through the inspection port. Some people think it is not very reliable reading but I don't care I am using it to monitor the temp it the tranny not the lines. Just my opinion.
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Rich_z28
May 6, 2003 08:38 PM
