A4 Problem 2nd and 4th gear band breaking
My 2nd and 4th gear band is constantly breaking and i'm getting teaked by it. I have already chaged my Transimission and stills break. What could the problem be:rolleyes: :mad: :death:
where does it break? what brand band is it, is it always the same kind? its probly your shift kits fault, i know one guy on here talks about shift kits taking out the band and the 3-4 clutches.
Who's 2/4 servo are you running and I think you have the pin adjustment on it set to "tight".
Ellis, you out there??? answer this post bro :) |
The breakage is usually (1) Too big of a 2nd gear feed hole in the valve body plate. (2) No or little accumulation. (3) Too much line pressure at light throttle openings. (4) Too large of an apply servo. I have never had a band break when everything is matched (feed hole size in the valve body plate, accumulation, apply servo, etc.). If I can be of help let me know? The Trans-Go Performance Shift kit will not harm the 2-4 band if installed correctly. Just don't add more than one washer in the 2nd gear accumulator, not necessary.
