94 z28 4l60e
Old Sep 3, 2009 | 12:56 PM
fastlt1camaro's Avatar
94 z28 4l60e
I have a 1994 z28 camaro I just had new clutches and band put in so all the transmission fluid was drain I installed it and added new fluid it wont shift in to gear when I try to put it in gear the motor idles down like it going in gear but nothing else happens. When I added the fluid before start up it was full then I warmed the car up and the level has not changed. Am I doing something wrong? I checked the fluid level its full. Please help!
Old Sep 3, 2009 | 01:16 PM
RUDEDOG's Avatar
Read this thread. Not saying this is your problem but it's good info. https://www.camaroz28.com/forums/sho...ht=broken+pump
Old Sep 3, 2009 | 02:58 PM
The converter is spinning freely don't understand it. When i pulled it to put the new clutches and band in it went in to gear fine but now I don't know.
Old Sep 3, 2009 | 03:02 PM
When i took the trans out there was a little white/clear plastic line on top of the trans what the heck is it would that do any thing?
Old Sep 3, 2009 | 06:24 PM
LearJet's Avatar
I believe thats just the vent.
Old Sep 3, 2009 | 07:28 PM
lt170chevelle's Avatar
If the car wont move at all ,like physically try to push it in neutral,then you might have too long of a bolt in the middle of the vb.
just a thought ...i had ran into this before
Old Sep 3, 2009 | 11:18 PM
Performabuilt's Avatar
Supporting Vendor
If the car wont move at all . Unhook a cooler line and start car if no fluid sprays out you broke the pump during installation , Was the converter fully seated in trans before you bolted trans to car?
Old Sep 4, 2009 | 12:20 AM
The Untouchable's Avatar
did u remember to fill the TC before installing the trans?
Old Sep 4, 2009 | 02:13 AM
I did unhook the lines and started the car there was no fluid coming out ****. Does that really mean the pump is broke? Could there be another explanation? I did not fill the TC up I put maybe a quirt of TF in.
Old Sep 4, 2009 | 02:31 AM
I had the engine out and bolted the TC to the flexplate first then slid the Trans on.
Old Sep 4, 2009 | 07:39 AM
RUDEDOG's Avatar
The correct way to install the trans is to fully seat the converter in the trans and then bolt the trans to the engine.
Old Sep 4, 2009 | 01:56 PM
LearJet's Avatar
...And you may need to shim the converter away from the flexplate in order to maintain proper pump engagment.
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
Brake_L8
Jan 20, 2015 09:44 AM
Jan 5, 2015 07:14 PM
thenewkid
Nov 27, 2014 09:41 AM
