94 / 95 4L60E compatibility
I have a 94 Z28, and I need to pull my trans out for a repair. While the trans is getting repaired, I have a 4L60E from a 95 Z28 that I am going to put back into the car so it is driveable. Question is, are they compatible? I know it will bolt up and everything, but what about the electronics?
Re: 94 / 95 4L60E compatibility
Although I am not a tranny expert, I will try to help you. If I'm in error at least I tried.
To the best of my Knowledge, the '95 up trannys used a pulse width modulated lockup & the '94 used basic on/off lockup control.
I believe the '94 trans will not work properly with the PWM lockup of the '95 computer, but I believe the opposite ('95 trans in a '94) will work OK.
At least this is something to base your research off of.
