700R4 shifting RPM W/new crate 350TPI
I have my car in the shop with a new crate motor being installed. The engine is the Scoggin Dickey Vortec TPI. It has a redline higher than my old stock 350TPI. I also bought a new Mad Dog Punisher 700R4 built to 450HP with a lock up conv. I also got a PCMforless custom chip. My question is will I be able to use the higher RPM's without doing something else? Will my car shift at the same RPM it used to?
Re: 700R4 shifting RPM W/new crate 350TPI
Ok cool, so it is vacuum. I'll have that looked at. Yea I got a Hurst dual gate so that might be the easy way out for a while. Thanks guys.
Your 700 isn't vacuum controlled
. If your shift points are off, you'll need to modify the governor weights and/or springs to get it correct.
Frank
CPT
. If your shift points are off, you'll need to modify the governor weights and/or springs to get it correct.Frank
CPT
Frank
CPT
CPT
FMFRacing88
May 25, 2015 08:08 PM
hotrodyou1
Dec 20, 2014 10:05 PM
