700R-4 Shift Points
Old Jun 5, 2004 | 02:26 PM
LJ93Z28GM's Avatar
700R-4 Shift Points
Have a 93 which still has the old non computer controlled 700 in it.
My shift points are higher than stock.
I know I have to modify the govenor and it is somewhat trial and error.
My question is what on the governor changes what. I know it is possible to alter the weights and the springs or to change them out to lighter ones. Does one do the part throttle shifts and one does WOT shifts.
Trans has always shifted somewhat earlier than I wanted it to. TV cable is set properly and is not the problem.
I changed one spring of the two to a lighter unit and it made the part throttle shifts later as I wanted but now it hits the rev limiter before it shifts. I tried another prom chip with a higher rev limiter and it is about 300 more rpm than I want based on the cam and rev limiter in the chip. Car will shift if I let out of the throttle for a moment and then get back into it.
TIA.
Old Jun 8, 2004 | 12:14 AM
LJ93Z28GM's Avatar
Some has to have tinkered with a governor at some point???????
Old Jun 8, 2004 | 01:36 AM
Taylor's Avatar
B&M makes a governor recailabration kit. It comes with different springs and wieghts. I paid like $30 from summit for it. It is a pain in the but adjusting it but works well. I found the best way to do it is to use datamaster to recorded the rpm it shifts at and go from there.
Taylor
Old Jun 8, 2004 | 05:20 PM
LJ93Z28GM's Avatar
Thanks for the info, what did you alter the weights or the springs and in turn what did it change??? Did WOT change only or the part throttle shifts as well?
Old Jun 8, 2004 | 10:30 PM
Taylor's Avatar
I changed the weights and springs. The change all depends on which one you use and stuff so I can't really tell you which one to use. It changed my WOT and part throtttle shifts.
Taylor
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
number77
Sep 6, 2002 01:29 PM
96z
Sep 5, 2002 07:53 PM
