6 Speed Manual Spewing Fluid at WOT/High RPM
I've got a strange problem with my trans fluid belching from the top vent port every time I make high RPM runs.. I dont have it figured out other than any WOT/High RPM run it spews fluid all over the right side exhaust and sometimes is still dripping by the time I get home... mile or two from the spew.
I have a hose connected to the upper vent and it comes down the right side and is basically open (has a closed hose end on it but no real plug)
Am I missing something here? It's not overfilled since this has been happening now for about a year, by now it's possibly a little low.
Thanks for any comments.. Im confused.
Have you checked the fluid level in your tranny? Still sounds like it may be overfilled.
The vent tube has a bracket attached to it, which it supposed to be under one of the upper bellhousing bolts. That keeps the tube from hanging down. There should also be a small white nylon plug in the end of the vent tube. The nylon plug has a small hole in it.
as simple as that seems I was totally confused. You the man!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
guionM
9
Aug 29, 2002 01:48 PM
