6 speed lunges forward with clutch in!
only when i hit the gas even with the clutch in, its like its half engaged or something, car has a mcleod street twin and adjustable slave cylinder. i have played with the adjustment to try and cure it with no luck, the car also has a vibration to it while driving. anyone ever have this issue?
car was working fine then all of a sudden started doing this. also this may sound dumb but when i press the clutch in shouldnt the fluid in the resivour move? bucause its not moving.
Fluid Movement
I just checked my 96 m6 that is in perfect working order. The clutch fluid in the resevoir did not move to any noticeable extent when the clutch was pressed in. So I would say that no movement is not a sign of a problem.
Same Issue
I had the same issue a few months back after changing my clutch a pressure plate. I ended up going back in and changing the flywheel and it cured the issue. May not be your problem..but sure was mine.
