4L60E input drum air check issue
Old May 10, 2006 | 04:45 PM
rocmemphis's Avatar
Question 4L60E input drum air check issue
Late model 4L60E
When I air check the pistons in the input drum I get a hiss from all three. I have taken the input drum apart and I cannot find any problems with the seals...moulded seals by the way.
I bought a new forward, overun, and 3-4 piston. I am still getting the same problem. When air is applied to the 3/4 feed I can hear hissing from the drum. When air is applied to the overun feed and the piston is at its maximum travel air leaks from all sides. Any ideas?
Old May 10, 2006 | 06:33 PM
jay_lt4's Avatar
Re: 4L60E input drum air check issue
a small amount of air is normal, remember there will be fluid doing the job and not air, air can fit through smaller gaps than atf fluid
David Dorris
Jan 17, 2015 08:10 PM
95chwagon
Jan 13, 2015 09:19 PM
Jan 5, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
danielbmx
Aug 27, 2002 11:11 PM
