4L60(700r4) to T56 Conversion Help
Hey guys,
I've been seriously considering doing the swap of my A4(4L60) in my 93 Z to a T56. The only problem that I am having is that all the instructions that I am finding online are for swapping a 4L60E to a T56.
I was wondering if anyone knew if everything hooked up all the same with the electronics and such.
Thanks.
~Kevin
Thanks.
~Kevin
I just did it in my 93 Z28. Everything is exactly the same, except a couple of the wires you have to connect in the interior are different colors than 94+, I looked at the diagrams in a Haynes to figure it out, not hard. You'll also need to wire up a Dakota Digital speedo recalibration box($80) to make the speedo work with a 94+ T56, not necessary with a 93 T56. I still haven't wired the speedo yet so i can't testify to the dakota digital box yet, though it is supposed to work.
Kevin
Kevin
Awesome thanks...couldn't the dealership maybe do that? I already know that I will have to re-program the computer(which is what I would do from the dealership) so wouldn't that correct the speed-o problem?
Thanks for your help.
~Kevin
~Kevin
I just did the swap in my 93 TA I got the tranny out of a 93 Z28 and everything went ok BUT my speedo is way off, its reading 160MPH halfway through first gear.. this I dont understand becuase everything is from a 93.. I wonder if I need one of those recalibration boxes.. where can I get one?????
