4.10 gears in a A4
Old Sep 13, 2005 | 11:55 AM
Honda Hunter's Avatar
4.10 gears in a A4
I noticed at 80mph cruising I'm at 3250 rpm's. Is that about right?
Old Sep 13, 2005 | 12:44 PM
arieso94Z28's Avatar
Re: 4.10 gears in a A4
Dang I have 4.11's in my car and when I am doing 80mph my rpm's are at 2,600. But I have a 6-speed though.
Old Sep 13, 2005 | 12:56 PM
LWillmann's Avatar
That sounds about right
Old Sep 13, 2005 | 01:02 PM
JDM-93_Z28's Avatar
I have 3.73s in a six speed and at 80 im like...around 3grand
Old Sep 13, 2005 | 02:12 PM
You can calculate speed and RPM here:
http://www.f-body.org/gears/
Old Sep 13, 2005 | 02:27 PM
Jameslt1TA's Avatar
Kinda hurts the ol gas milage dont it
Old Sep 13, 2005 | 03:24 PM
Gord's Green Z28's Avatar
Put your car in it's 1:1 ratio gear (3rd in autos, 4th in manuals)....drive at 70 mph. Your RPM will tell you your axle ratio.
Old Sep 13, 2005 | 03:35 PM
I'm missing to much info to get a correct reading when I try to use the calculators online. That's why I was trying to see where others with A4's and 4.10's are at in the rpm range at a certain mph.
Old Sep 13, 2005 | 03:36 PM
Gas prices is the last thing I worry about in the middle east.
Old Sep 13, 2005 | 03:38 PM
I thought it was 3rd gear with the tq converter locked up or something?
Old Sep 13, 2005 | 10:39 PM
Capn Pete's Avatar
3250 seems a little high? But then again, you've got a 3500 stall converter ..... that's probably the cause. Mine would cruise right around the ~3k mark at ~80 mph.
Gas mileage wise? Well, to be honest, I put back the 2.73's this summer because I've been doing a lot of highway driving (and not much racing) but I really haven't been getting very good mileage anyways, and can't honestly say that my fuel consumption (on average, with a ~50/50 mix of city/hwy) has changed very much one way or another. Sure, 100% straight highway cruising, I can get a little over ~300 miles to a tank, but even with 4.10's, I could get around ~240 or so ... still not bad.
Old Sep 15, 2005 | 11:29 AM
1SlowFormula's Avatar
What info are you missing? I have a similar version of that calculator in my sig.
All you have to do is enter the vehicle and change the gear ratio to 4.10, if you have changed the tire size then enter it, if they are factory then it will auto populate then you just need to press calculate.
When the results come up on the screen to the right, then you go to the 4th gear column scroll down untill you see 80 then look over and see what RPM the math says the motor should be rotating at. BTW, with stock tires and 4.10's you should be closer to 3000 RPM's, to get higher then 3200 you need tires smaller then 24' tall... BTW, is your speedo reading correctly?
*** EDIT ***
This does not account for an unlocked converter, but the converter should be locked at that speed...
Old Sep 15, 2005 | 01:58 PM
I don't know what you would be missing.
Allow for tach error, too.
Drtryder
Apr 22, 2015 04:17 PM
camy 1993
Feb 1, 2015 07:16 PM
Noer
Parts Wanted
Jan 19, 2015 10:19 AM
GRN96WS6
Sep 8, 2002 10:45 PM
funina91ss
Aug 6, 2002 11:20 PM
