3600 stall and Trans go
Old Sep 29, 2003 | 11:48 PM
94 TA TT2S's Avatar
I am having this done hopefully this week, I have heard that people use some of the parts and some all and what not....What do I need to use and not use???? And should one follow the video or the written instruction...Thanks for the help in advance
Old Sep 30, 2003 | 03:25 AM
AL SS590 M6's Avatar
Moderator
Re: 3600 stall and Trans go
You use all of the parts that apply to your year of car. Different mods to different years.
I followed both the vid and hard copy where each applied.
And don't forget to put a good trans cooler on too!
Old Oct 2, 2003 | 12:26 AM
Pro Built Automatics's Avatar
Use the written instructions, as they are kept pretty much up to date. If you want to increase the capacity of this unit with the high stall unit you are planning on using, change the 2nd gear valve body plate apply hole to .096, and make sure you use no more than one spacer in the accumulator, along with the Corvette servo. This will keep the 1-2 part throttle smooth and still firm at WOT. For 3rd & 4th gear change hole size to .155. I have found this to work extremely well in these units, especially if you want it to last in 10-11 second vehicles. This information is from Trans-Go.
Old Oct 2, 2003 | 12:29 AM
94 TA TT2S's Avatar
Hey Pro Built
Is that on the paper?? that is in the box????? I have it...if not should I make a note????
Old Oct 2, 2003 | 12:40 AM
You will have to make a note of this.
Old Oct 2, 2003 | 12:43 AM
94 TA TT2S's Avatar
Pro built I sent you an email as well
Check it out
Old Oct 2, 2003 | 12:51 AM
94 TA TT2S's Avatar
On the instruction sheet page 7 it shows the plate whole sizes.....Do I need to specify the a which has 3rd next to it, and e which has 4th next to it to .155???? is that what you are telling me?????
Old Oct 2, 2003 | 01:00 AM
94 TA TT2S's Avatar
also ....
My kit did not include corvette servo so 3 spacers????
Old Oct 2, 2003 | 01:46 AM
Moderator
Re: also ....
I'm using the stock servo and 1 spacer. I tried 3 and it hit so hard that I thought something was going to break.
Old Oct 2, 2003 | 01:49 AM
94 TA TT2S's Avatar
Would it make sense to do what pro auto said about the holes in the plate...Is that what he is talking about????
Old Oct 2, 2003 | 06:56 AM
revtime's Avatar
Just follow his instructions in his post and do the holes his way.
I trust that he knows what to do to get them to last.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
james007moore
Jan 1, 2016 01:14 PM
