3200 stall??
Old Oct 31, 2007 | 11:47 AM
NASCR46's Avatar
3200 stall??
Because we have an A/t we were told we should get a stall converter.My speed shop says a 3200 stall would be good.What is the advantage on a car which is driven for pleasure to cruise nights ,local car shows and taken to the drags 2-3 times per year (test and tune)?We also take it on vacation sometimes so it needs to be totally driveable,current mods are in the signature. Thanks
Old Nov 1, 2007 | 09:14 AM
Z-RATED94's Avatar
Just make sure you buy a quality converter that still has the lock-up.
Old Nov 1, 2007 | 07:11 PM
Jumper's Avatar
I have a 3200 stall converter and I am very happy with it, my car is a street car only and it drives great. I think you will be fine with anything between a 3200-3600 for what you want.
Old Nov 1, 2007 | 08:19 PM
STSturboLT1's Avatar
I also have a 3200 Vigilante converter, and it's primarily a street car. It took a little getting used to at first, because there's less coupling at low rpms, but it's not bad at all, and now that I'm used to it I don't even notice.
Old Nov 1, 2007 | 09:06 PM
ttop1986's Avatar
Keep in mind if you get a Vigilante, they are underrated. My 3000 is more like a 3200 stall. A 2800 vig is more like a 3000 stall. Also add a transmission cooler like a b&m supercooler.
Old Nov 5, 2007 | 01:40 AM
Future_Z_Owner's Avatar
Yes i have a Vig 3200 and im about to make a post about it so you might want to check it out here after you see this. Yank and the Vigilante are the 2 most popular brands for our cars. If you do get a stall converter like a 3200, it will take some getting used to. Mine is a bit smaller than the factory. Its a 9.5" MAKE SURE YOU GET A BIG TRANSMISSION COOLER. Thats very important. Also a tranny temp gauge would be a good piece of insurance for your investment. Your trans should be around the same temp as your engine. If its higher, lay off for a bit.
Old Nov 5, 2007 | 10:10 AM
Z-RATED94's Avatar
You don't need a big cooler, just a B&M super cooler.
Old Nov 8, 2007 | 11:57 AM
NASCR46's Avatar
Ok,I called to Precision who makes Vigilante and the tech guy suggested a 2800 stall since the car is mostly street driven.Would I still need a trans cooler?Forgot to ask him.
Old Nov 8, 2007 | 02:05 PM
ttop1986's Avatar
Yeah, I'd still get one. I have the top one on here (59-70264):
http://thunderracing.com/catalog/?ac...vid=4&pcid=175
Old Nov 9, 2007 | 09:33 AM
Z-RATED94's Avatar
If you really want to wake that car up, add some 3.73 gears with that converter. Or better yet, get a 3200 or 3600 with those mentioned gears. You have some good HP, put it to use. You will of coarse need better tires with any decent converter, gears or not. And yes, get the cooler mentioned, thats the one I have too.
Old Nov 9, 2007 | 05:17 PM
MasterZ28's Avatar
Same here, they say 2800 but noooo, they under rate their sh*t
Get an Auxilary cooler for the tranny, they actually work, no BS, i know a guy that has done nothing but tranny work for 30+ years, the best results are with Hayden, man, i am planning on getting one.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
