3000 stall issues
Old Jun 10, 2004 | 11:44 AM
19formula94's Avatar
3000 stall issues
I have my vig. 3000 put in yesterday, everything was going fine on the way home, until i hit traffic on the highway and had to slow down from 75 to 40...i tried to accelerate and the car wouldnt go into gear....coasted off the highway and hit a stop light, then everything worked fine again...made it home with no problems.....does the computer need tuned?? I'm putting the shift kit in sat. so someone may be there with LT1 edit, should they be able to fix the prob?
Old Jun 10, 2004 | 06:30 PM
Spinner's Avatar
Trans cooler?
Old Jun 10, 2004 | 08:39 PM
AmericanPsycho's Avatar
Re: 3000 stall issues
You should not need any programming in order for the new converter to work. Did you get any codes? The only problem I had was that it stalled a few times until the PCM "learned" the new stall converter. I would go through the transmission again when you install the shift kit and make sure everything is good including the transmission fluid levels.
Old Jun 10, 2004 | 10:09 PM
yeah i got a tranny cooler in, it only acted up that one time, working fine today....maybe it just needs time...i hope the shift kit makes it feel a little better, cant stand the sluggish shifts
Old Jun 11, 2004 | 10:42 AM
2001NBMZ28's Avatar
I had shifting issues on the way home from my Vig install too - they didn't have the fluid level right, had to add 2 quarts.
rocknroler69
Apr 29, 2015 10:24 PM
thenewkid
Apr 12, 2015 07:42 PM
thenewkid
Nov 27, 2014 09:41 AM
veryslowfbody
Aug 22, 2002 04:31 PM
demea
Feb 19, 2002 01:48 PM
