3.73's
Old Jul 19, 2004 | 09:35 PM
LetMeBurnU's Avatar
3.73's
I was looking into the 3.73 pro-street gears by strange and i saw it has 2carrier and a 3carrier. what do they mean by 2 or 3 carrier?
Old Jul 19, 2004 | 10:38 PM
Capn Pete's Avatar
Re: 3.73's
Since you're car is an SS with an A4, I'm 99% sure they came with 3.23 gears, which are on a 3-series carrier (the carrier contains the posi / limited-slip part of the differential, as well as that is where the ring gear bolts to). If you have 2.73 gears, then you've got a 2-series carrier. If you're upgrading to 3.73's, buy them to match the carrier that's currently in your car.
Old Jul 19, 2004 | 10:55 PM
slayer6x6's Avatar
Re: 3.73's
The ring gear on a 2 series carrier is a little thicker than a 3 series carrier.
Old Jul 20, 2004 | 01:27 AM
LetMeBurnU's Avatar
Re: 3.73's
So a 98-02 z28 a4 is considered as a 3 carrier right?
Old Jul 20, 2004 | 04:53 AM
Capn Pete's Avatar
Re: 3.73's
No, not always. The cars using 3-series carriers are 3.23 geared A4's, or 3.42 geared M6's. However, 2.73's are the more common A4 gear, and they are using a 2-series carrier (and they're available through all the years, '93 - '02).
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
