3.73 in 6-speed
Old Apr 23, 2008 | 01:09 AM
TJ Chapman's Avatar
3.73 in 6-speed
coorect me if im wrong but wouldnt it be kinda crappy having a 3.73 or higher rear end in a 6-speed car? im not seeing the benefit like there would be in an auto. wouldnt the higher rear end gear ratio make you have to shift more often in a 1/4 mile race? u might hit 5th gear no? what rear end gear ratios do most modded 6-speed fbodies street strip use?
Old Apr 23, 2008 | 02:44 AM
jay_lt4's Avatar
most 6spd guys go with 3.73-4.10's
Old Apr 23, 2008 | 03:19 AM
Capn Pete's Avatar
Lots of guys opt for 4.10's behind the T56! The beauty of double over-drive is you can still get the same mileage as an A4/2.73 car, with the acceleration of M6/4.10!
Old Apr 23, 2008 | 01:09 PM
TRICK95's Avatar
It really depends on a number of things, like what mods the car has, what the rev limiter is set on, and just how fast the car runs the 1/4 in are all factors.
I have 4.11s, in a Moser 12-bolt.
For the automatic, plans are likely to keep replacing stock 10-bolts, with 3.73 gears (you can buy 10 or more 10-bolt rears complete for the price of 1 12-bolt).
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
