3.42s shift points
Old Aug 26, 2003 | 05:40 PM
My Mighty White 95 Z28's Avatar
3.42s shift points
What is the best shift points for a A4 with 3.42s? Any help would be greatly apprecaited. Thanks.
Old Aug 26, 2003 | 06:20 PM
anaik's Avatar
Shift points are determined by where you make your power, not by what rear gear you have.
Old Aug 26, 2003 | 07:15 PM
jkipp84's Avatar
I would think you'd want to adjust them with gears (I'm asking) since it may normally shift at a certain mph with 2.73's, for instance, you'd probably want to move that down a bit if you switch to 3.42's. Reason being that you'd be at a higher rpm at the same mph with the new gears. Could get annoying. Or am I off in left field here?
cmdeshon
Dec 27, 2014 10:06 AM
number77
Sep 6, 2002 01:29 PM
96z
Sep 5, 2002 07:53 PM
