3.23 to 3.73
Old Dec 9, 2009 | 02:47 PM
Tanner_94_Z28's Avatar
3.23 to 3.73
ive wanting to do a gear change and my 94 formula has 3.23 and i want to put 3.73 can i just change the gears with the same carrier or will i have to get a different carrier too? and i also hear something about a pinion bearing?
Old Dec 9, 2009 | 04:46 PM
Z-RATED94's Avatar
Your carrier is a 3 series so your good there with the 3.73s. Many people use Motive gears, set up correctly their pretty quite. A full install kit will include a new pinion bearing if you think you need it. If not, you can use the cheaper install kit.
Old Dec 11, 2009 | 02:31 PM
so could i put 3.42 on the carrier i already have no problem without changing anything?
Old Dec 11, 2009 | 02:57 PM
Yes, you could do that, too. Don't forget computer programming.
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
colts0455
Jul 24, 2015 04:51 PM
