1994 z28 need help with clutch
Old Jun 15, 2012 | 09:09 PM
Tinoco_559's Avatar
Hi I just recently got a 94 z28 with a 6 speed and wanted to know if I needed to change my clutch or if it's somethig else. What happens is when I'm on the freeway or regular city driving when I step on the gas it revs a whole lot more than what it goes. Also when sitting still I noticed I can keep it on first gear and let go of the clutch pedal and the car won't stall, it'll just stay idling and I'll smell the clutch burning, i tried it on all gears same thing happens.
Old Jun 15, 2012 | 10:36 PM
bw_hunter's Avatar
Re: 1994 z28 need help with clutch
You need a clutch. Replace the pressure plate and the throw out bearing at the same time. And don't forget to replace the pilot bearing as well.
With all that slippage you probably have some spot discoloration. GM says you can't refinish the flywheel ( I did and got away with it) so you better figure that it while you're in there....
Old Jun 16, 2012 | 12:57 PM
jmd's Avatar
jmd
Post Re: 1994 z28 need help with clutch
Originally Posted by bw_hunter
You need a clutch.
This.
No they don't. That's just an accounting change in procedure to get cars completed and out of the shop. And that didn't get implemented until around 2000 anyway. Procedure was to resurface until that time.
Old Jun 16, 2012 | 01:09 PM
jloshotz's Avatar
I resurfaced as well with no issues
Noenav
Mar 1, 2019 07:38 AM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
cmdeshon
Jan 4, 2015 11:15 AM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
