12 bolt install
Old Apr 21, 2004 | 09:00 PM
oneledvr's Avatar
Question 12 bolt install
I want to install a 12 bolt rearend in my car for obvious reasons. However, I want to maintain the handling of my car. Is there a direct replacement unit out there?
I have heard with the Moser you have to install bigger clamps to hold the sway bar on and you may have to install a different panhard bar also
Any and all information is appreciated.
Old Apr 21, 2004 | 10:37 PM
The Strange is a total, direct, plug-and-play replacement. No modifications required. You might have to rotate the sway bar clamps a few degrees to keep the sway bar from hitting the bottom of the aluminum cover plate.
The Moser does require larger sway bar clamps, because it uses larger axle tubes.... but that is really a minor detail. Spohn sells modified brackets/u-bolts. I have never heard of anyone needing a different panhard rod. The torque arm mount needs an offset set of holes.... Spohn includes those on his TA's. Some people have found it necessary to shorten the driveshaft with the Moser.
There is also a KTRE that is virtually identical to the Strange, but KTRE has a very poor reputation due to some dishonest group purchase deals reported several years ago.
Old Apr 21, 2004 | 11:24 PM
oneledvr's Avatar
Thanks for info. Man, you got your car set up
My mission is mostly nice day driving and occasional test n tune. I am pretty **** when it comes to my car. Therefore, I don't like butcher and bang etc. to get things to fit. If the Strange unit is direct replacement I will be going with it.
Upon installing the Strange unit how would you suggest checking the drive shaft/differential pinion angle? and any other critical info.
Old Apr 22, 2004 | 01:10 AM
1BAD86Z's Avatar
AXLE SWAPS
i am local and i do alot of work out of my garage, i used to work at DTS and i am still state certified. i have done 4 axle swaps for f-bodys and can point you in the right direction. contact me at www.skoresky@yahoo.com or phone me at 586-630-1098. thanks scott k.
Old Apr 22, 2004 | 11:49 PM
oneledvr's Avatar
Scott,
I tried sending you an email but it wouldn't work?
Old Apr 23, 2004 | 01:11 AM
1BAD86Z's Avatar
e-mail???
give me a call on my cell 586-630-1098 after 1pm. i work afternoons and my schedual is kinda f...ed up.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Richardan15
May 30, 2015 08:36 AM
maybe2fast
Mar 16, 2015 09:45 AM
