12 bold fluid capacity
Old Dec 31, 2003 | 10:27 AM
BPS's Avatar
BPS
Question 12 bold fluid capacity
I need to change the fluid in my starange 12 bolt it has the LPW aluminum cover with fill and drain plugs.
looking at it it seems that if i fill to spill then the diff will be over 3/4 full of fluid, as the fill plug is rather high on the diff cover
Is this correct - does one fill to spill or is there a set amount of oil and additive to use?
Old Dec 31, 2003 | 02:05 PM
MadneSS's Avatar
I have a strange 12 bolt w/ aluminum cover also. When I changed mine, I used 2 quarts of fluid and one bottle of the GM additive. Those were the instructions that I got with the rear. I put the same amount in that I got out of it. Personally I think 2 quarts is too much because after about a quart and a half, it started to come out of the check plug on the side of the pumpkin.
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
