01 Z28 rear end noise
Old Mar 6, 2005 | 06:07 PM
gabmando's Avatar
My 2001 Z 28 has a hair under 47K on it. It has the stock rear end with the 3.23:1 rear end ratio (GU5). I start getting a whine at low speed that increases but I can't tell if it's from the center or right rear wheel. I don't think it's ring gear / pinion noise as it does not go away when I take my foot off the gas pedal. vehicle is not driven hard. Pinion shaft seal was replaced by dealer at 30K but everything seemed ok.
Anyone has any ideas or similar experience? I also need help finding instructions on rear end set-up in case I decide to take it apart. Thanx.
Old Mar 7, 2005 | 10:25 AM
97_Z28's Avatar
Re: 01 Z28 rear end noise
It could be that you have a bad rear axel or rear wheel bearing.
Old Mar 7, 2005 | 10:28 AM
97_Z28's Avatar
I state this because I recently purchased a 1997 Z and it had a bad rear axel, so it was loud.
oldschool
Feb 9, 2016 09:21 PM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
