What's your best R/T?
Best I could muster was a fluke .501. Best one prior was a .552.
What kinda lights are you guys pulling?
~Joe~
My WebPage
My 1995 T/A
AIM twocents29
12.8 @ 108.55 Bolt-ons only...
Best 60' 1.78 Stock converter.
Want to make your own clear corners for Firebirds, TransAms, and Formulas?
~Joe~
My WebPage
My 1995 T/A
AIM twocents29
I try to pull a .52x to .53x running in street. I never had a .500. Lots of .50x's and of course the perfect red of .499. The key word is focus. Stage the car exactly the same spot and go on exactly the same key. I wear sunglasses all the time even at night. Where you stage and how the car launghes effects your RT. This Sunday I had a problem with the bird and ran the Trailblazer. This is how I adjusted for a better RT.
Run 1
Deep stage to just turn off the prestage light, all tires 45lbs, powerbrake to 1800rpm, and went on the 3rd full yellow .386
Run 2
Deep stage to just turn off the prestage light, all tires 40lbs, powerbrake to 1600rpm, and went on the 3rd full yellow .440
Run 3
Deep stage to just turn off the prestage light, all tires 35lbs, powerbrake to 1500rpm, and went on the 3rd full yellow .529
and won the round.
Run 4
same as run 3 but I was a little late on the light .567 (missed my mark) and lost the round by .0042.
By changing tire pressure and launch rpm I was able to "slow the truck down" to get my RT time out of the red light zone. I still staged the same spot and went on the same place on the tree.
'95 FORMULA Blue-Green Chameleon, M6, Suncoast WS6 ram air hood, K&N, Granetilli MAS, BMR supension, Hypertech program & 160 stat, LT4 knock module, Hurst shifter, Star Stage II clutch, Borla Cat Back, Goodrich Drag Radials, Moser 12-bolt 4.11 rear, 13.18@102 1.90 60' on the breaks, last run of the 2001 season
[This message has been edited by kazman (edited July 10, 2002).]
Run 1
Run 2
Run 3
and won the round.
Run 4
i have had a few .500's, but never during eliminations. i have a ton of .50x's during elims though, on an average day i will sit in teh mid to high .52x's or right around .530. not the greatest i know, but it gets the job done most of the time.
one way to really mess with your reaction times is front tire air pressure. always set it in the same spot as soon as you get to the track.
later
tim
NJ SPEEDER
91 Camaro RS
305TBI/700R4
12's Coming Soon
2nd Annual East Coast F-Body Nationals
July 20,2002
www.geocities.com/njspeeder
My MAFB.ORG Home Page
http://www.mycar.net/mafb/registry/detail.cfm?id=299
later
tim
NJ SPEEDER
91 Camaro RS
305TBI/700R4
12's Coming Soon
July 20,2002
The best i have mustard up .523.Other than that i live in the .6xx.Dont know why guess need more practice.
95 Z28 A4 blue with black racing strips
loudmouth exhaust,mac headers,az-speed marine 52mm tb and cold air intake,hypertech programmer,power pully's, msd ingition,eibach pro kit,hotchkis rear supension,hotchkis strut tower,performance spoiler,drag radails
Best ET 13.69
Best MPH 100.52
Best ET 13.69
Best MPH 100.52
Generally .52-.53. I time trials I will either forget about the tree or try to kill it depending on what type of message I want to send out.
The other end of the track is equally as important as the start. I won three rounds last Sunday due to breakouts...
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
My best raection time is one that nets me a win and is better than the opponents. Anything else doesn't matter. my average reaction time is usually in the .510 - .520.
My brother won a race with a .502 reaction to the opponents .503. He ran his dial with .005 and she ran her dial with .006. Margin of victory .002 sec. He has also lost a round with a .500 light. So a perfect light is not allways better.
Take Care,
Wayne Best
Best Racing
67 rs Camaro
87 Formula 350 w/388cu.in. motor
www.geocities.com/best_racing
Take Care,
Wayne Best
Best Racing
67 rs Camaro
- 355 cu in Chevy
- 12.5:1 compression
- 10.90s @ 120 mph
You guys are all beating me, I mostly autocross and am fairly new to drag racing but my reaction times are in the .8xx's, I try to ease off the clutch too much because my car cannot get outa the hole! I have enough power but can't get it to the ground, I need to get some slicks.
Guest
Posts: n/a
I cut a .500 for the first time on Friday night You don't need great tires to cut a good light. If you are pulling .800s consistently, then I think you need to change your technique. Are you going as soon as you see the third yellow? If you are and are still .300 off, then try going simulataneously with the light (don't wait to see it). If that doesn't work, then try to go as soon as the 2nd yellow goes out. Etc. Etc. Just experiment. Good luck.
Rich
Rich
I've made 13 passes... in my life.
First 7 weren't anything to talk about, and resulted in shattered spider gears at the tree on run 8... to the tune of $1700.
Last Friday was the first time back. After 3 tuning runs, I picked up my first round win with a 0.523 R/T while running a 14.508 on a 14.500 dial in. A 0.031 total package!
Second round wasn't great package-wise. I ran a 15.0 @ 68mph... the opponant was WAY back so I was on the breaks pretty heavy. Although I did cut a perfect 0.500 on that run!
This "racing stuff" is kinda fun.
I'm with Rick. If you're that far off, you need to pick a different spot on the tree to launch at. Assuming you're on a standard tree (0.500s per bulb) you'll need to launch a bit more than 1/2 a bulb sooner.
I found the 0.523 above by launching when the third light JUST lite up. The 0.500 I ran (slip shows it was 18 minutes later) I left just as the second bulb went out. I know it sounds insane, but worked. Obviously your car will probably "load" different that someone elses, so don't hold me to the TIME to launch, just that adjusting between bulbs can be done.
I've also found that I ran MUCH better if I watch the tree light up for the race in front of me. Sort of a visulization technique I guess. Think of playing baseball and practising your timing on the picture while you're on deck. Same idea I guess.
There's no point in trying to tune your accuracy before you get some sort of precision established. My first two runs were 1.2xx and 1.1xxx Took 10 runs to get to the 0.5xx range... kinda lucked out with a perfect light on the 12th run (I don't think it's very typical to get one so soon, but I'm not much of a drag racer so I couldn't tell ya for sure). Worked for me I guess.
[This message has been edited by Steve in Seattle (edited July 17, 2002).]
<font face="Verdana, Arial" size="2">Originally posted by bestracing:
My brother won a race with a .502 reaction to the opponents .503. He ran his dial with .005 and she ran her dial with .006. Margin of victory .002 sec. He has also lost a round with a .500 light. So a perfect light is not allways better.</font>
hchap63@hotmail.com
01/SS, Black A4, TR224/112, ARE stage 2 heads, lid, FTRA, PMAF, PTB, Grott LT, true duals, NGK, ASP pulley, Vig 3200, LCA, poly TAB, Convo pros, ET Streets, 3300 raceweight. Little bit of juice..
Best ET: (All bolt ons) 11.496@116.42 (1.52)
Current best after Head & cam & nitrous:
10.88@124 (1.60)
Motown Muscle King of The Hill winner 6-8-02. Want some? Get some!!
RIP #3 Dirty Dale!!!
hchap63@hotmail.com
10.88@124 (1.60)
<font face="Verdana, Arial" size="2">Originally posted by Steve in Seattle:
wow... remind me not to race your brother. A 0.007s package?!</font>
That is why he drives the 67 and I do all the tunning and mechanical work
Wayne Best
Best Racing
67 rs Camaro
- 355 cu in Chevy
- 10.90s @ 120 mph
