What Will I Run Before and After? (another one lol)
Old Apr 14, 2006 | 05:17 PM
93redBirdMan's Avatar
I just wanna know what you all think I'll run before i get the heads/cam on there and what I will run AFTER the heads/cam. I'm guessing 13.0 right now, and 12.5 after
Old Apr 14, 2006 | 05:19 PM
kick Z tail out's Avatar
Re: What Will I Run Before and After? (another one lol)
13.0 now sounds about right... What heads are you getting? You should do better than 12.5 regardless, and depending on the heads you may be into the 11s pretty easily.
Old Apr 17, 2006 | 11:19 AM
The heads are stock castings, flowing about 260cfm or so. Not sure yet because they havent been flow tested. You think I can run 11's??? Wow never even crossed my mind...
Old Apr 17, 2006 | 11:26 AM
TedH's Avatar
I recommend going to the local track and establishing a solid baseline prior to your next modifications. You may find out about other things that you may want to change/add to take advantage of your next step by actually putting it on the track. Things like a driveshaft loop and other safety equipment may also want to be considered.
Z28countrymama
Jan 22, 2015 02:50 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
artic94
Jan 15, 2015 01:42 PM
