What should this p.o.s run?
Old Jul 20, 2007 | 11:33 AM
Jazsun's Avatar
38k on it, w/ a very slight head gasket leak which doesnt effect performance (seals up very quick after warmed up, no coolant in oil, runs perfect). Stock plugs/wires still.
Thinking about taking it to the 1/4 next couple weeks.
Old Jul 20, 2007 | 04:38 PM
exgmguy's Avatar
Who makes this pos?
Old Jul 20, 2007 | 04:59 PM
Jazsun's Avatar
talken about the car in the sig.
Old Jul 20, 2007 | 08:25 PM
exgmguy's Avatar
I would guess high 13's would be in the ballpark.
Old Jul 21, 2007 | 03:23 AM
IdahoLT1's Avatar
whats the track elevation and approx. temperature going to be?
Old Jul 23, 2007 | 09:50 AM
Jazsun's Avatar
Elevation: 660 feet
Temp: Prolly around 70 F
Old Jul 23, 2007 | 12:08 PM
TedH's Avatar
With good air, no problems with the car, decent traction and a competent driver 13.5-13.7, at 100-102. I was running 13.5's with similiar mods way back when in decent air (although I didn't have a "tune").
Old Jul 23, 2007 | 01:33 PM
BassProCamaro97's Avatar
Good traction will be key. I would say high 13's probably if your on a street tire. If your on a radial then mid 13's should sound right.
Good luck with the piece
~Jim~
Old Jul 23, 2007 | 01:48 PM
JakeRobb's Avatar
Super Moderator
Originally Posted by BassProCamaro97
Good traction will be key. I would probably say high 13's if you're on a street tire. If you're on a drag radial, then mid 13's sounds right.
Fixed. All modern street tires are radials. A drag radial is an entirely different thing.
Fixed your grammar while I was at it.
Old Jul 23, 2007 | 01:50 PM
mdacton's Avatar
I would fix that head first.......
Old Jul 23, 2007 | 01:56 PM
danhr's Avatar
You should fix it now, before it becomes a bigger problem.
Old Jul 23, 2007 | 01:59 PM
mdacton's Avatar
Yeah....like pushing the car to its limits and putting AF under the tires doing 100 m.p.h
Old Jul 23, 2007 | 02:06 PM
Jazsun's Avatar
I'm gona bars leak it temporarily, since I dont have time to fix it for a while. The cars gone to WOT many times and never had a problem. Like said the head gasket is very very minor and seals up when full warmed. I add like a 1/4 cup every 4 months
Old Jul 23, 2007 | 08:18 PM
Heatmaker's Avatar
Advanced Member
Head gasket Leak... minor? hungh? sounds like a timebomb wiatng to blow.
Old Jul 24, 2007 | 11:53 AM
Jazsun's Avatar
You dont understand how minor it is, I contemplate even fixing it. The dipstick only went down maby 4 notches over 5,000 miles.
